aftermarket parts on a v6 to a v8?
Old Mar 27, 2013 | 11:28 PM
razor9546's Avatar
razor9546
Default aftermarket parts on a v6 to a v8?
I recently purchased a 2000 gt mostly stock. A friend of mine has a v6 that runs but doesn't drive but it has a dual exhaust flow masters and a k&n air intake. He doesn't need the parts and would probably sell them cheap. Would they work on a v8 stang or is that not a good idea?
Old Mar 28, 2013 | 12:08 AM
SXGT's Avatar
SXGT
get the mufflers but inspect for rust, no go on the intake. you might want to get his center dash piece as a back up incase your breaks one day. are his seats better? what year is his car?
Old Mar 28, 2013 | 10:37 AM
uberstang1's Avatar
uberstang1
Chupacabra
The parts wont work, that flowmaster kit isnt true duals its y pipe duals
Old Mar 28, 2013 | 04:09 PM
LilRoush's Avatar
LilRoush
Actually most V6 guys will use a GT cat back and modify the stock mid pipe. Depending on how he did it, the exhaust should work.
Old Mar 28, 2013 | 05:19 PM
SXGT's Avatar
SXGT
but he can cut just the mufflers alone off and use them.
Old Mar 28, 2013 | 06:30 PM
razor9546's Avatar
razor9546
Not sure what year his is but it is the same style as mine. Even if I just took the mufflers I could always weld them on to the stock pipes right? My car only has an MRT h pipe everything else is stock as far as the exhaust goes.
Old Mar 28, 2013 | 07:46 PM
SXGT's Avatar
SXGT
you should be able to cut your old mufflers off and have a shop weld new ones into place. it helps to know the pipe sizes tho. they can be up to 3" on some applications.
AMAlexLazarus
AmericanMuscle.com
21
Apr 4, 2020 02:16 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
rksnow1
Sep 14, 2015 08:46 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
