Mustang mystery problem????
Old May 22, 2013 | 07:42 AM
Seabee1993's Avatar
Seabee1993
Fuel filter, vacuum leaks, but if you're having fuel delivery problems. Might want to find out how to test your fuel pump with a meter.
Old May 22, 2013 | 09:42 AM
Dragonus18's Avatar
Dragonus18
Is it possible that maybe a seal is bad or wasn't properly put on? My rubber pieces are new from what I was told so maybe one wasn't put on right or needs to be resealed?
Old May 22, 2013 | 12:04 PM
Seabee1993's Avatar
Seabee1993
Seals on where?
Old May 22, 2013 | 01:51 PM
Dragonus18's Avatar
Dragonus18
Originally Posted by Seabee1993
Seals on where?
The seal that holds them in place.
Old May 22, 2013 | 02:12 PM
Seabee1993's Avatar
Seabee1993
Define "them", sorry you lost me...
Old May 22, 2013 | 02:49 PM
Dragonus18's Avatar
Dragonus18
The seals on the coils that prevent water or other things from getting in.
Old May 22, 2013 | 04:53 PM
uberstang1's Avatar
uberstang1
Chupacabra
The boots?
Old May 22, 2013 | 05:27 PM
Dragonus18's Avatar
Dragonus18
Originally Posted by uberstang1
The boots?
I guess that's their name. I know very little about this area.
Old May 22, 2013 | 06:59 PM
Seabee1993's Avatar
Seabee1993
Well, along with the boots, you should buy a chitons, and educate yourself. The coil comes in two parts, the coil itself which is exposed on top of the engine, the boot is what goes down into the spark plug well, and has a long coiled spring inside that goes over top of the end of the sparkplug.
There is no seal, it has a small lip that somewhat helps, there is really nothing to prevent water from entering the area hence why people have problems when they spray down their engines and then the coil will short.
Old May 22, 2013 | 10:14 PM
Dragonus18's Avatar
Dragonus18
Nothing you can do at all?
