Time for an oil thread!
Old Oct 9, 2005 | 02:58 PM
Birdieman4's Avatar
Birdieman4
Default RE: Time for an oil thread!
K & N makes a high performance oil filter that I use with excellent results.
Old Oct 9, 2005 | 07:31 PM
vfast's Avatar
vfast
I ♥ Acer
it's not so much the oil but the filter
this is what I do
1. use magnetic drain plugs
2. a magnet on my oil filter
3. syth. oil
4. hastings filter or amsoil
5. I pour a 1/2 qt in my engine to flush the old oil out the pan after it quits draining.
6. I use teflon tape on my drain plugs for a leak free job
Old Oct 9, 2005 | 07:35 PM
grabbem88's Avatar
grabbem88
it seems everybody likes the mobil 1 synthetic???i use the same,and i use the k&n filter..
Old Oct 9, 2005 | 10:53 PM
josh_0351's Avatar
josh_0351
ORIGINAL: Jglisson
What oil do you use?
Mobil1 (Fully Synth) 10W30
ORIGINAL: Jglisson
How often do you change it?
3K miles religiously
ORIGINAL: Jglisson
and why do you use what you use?
Had some bad experiences with Yellow (Sh!tzOil)...
Old Oct 9, 2005 | 10:59 PM
099gt's Avatar
099gt
royal purple 10w30 every 3000 miles.
Old Oct 9, 2005 | 11:58 PM
2003DSGT's Avatar
2003DSGT
i geuss this is why im a noob.... castrol gtx?? [&:] lol
Old Oct 10, 2005 | 04:39 PM
JT2000's Avatar
JT2000
Mobil 1 and Fram every 3k miles. And I can't find a magnetic drain plug. Can anyone point me in the right direction?
Old Oct 10, 2005 | 06:06 PM
FWP!'s Avatar
FWP!
If your car has never had synthetic before, don't switch to synthetic, you will burn some off in between oil changes. Like my Mustang, I bought it with 46k miles, leaked a little oil, I had to put a quart in between oil changes. I started using Quaker State High Mileage oil (red bottle) and I don't lose a drop of oil anymore. If an engine goes from using regular oil its whole life to using synethetic, the cleaning agents in the synthetic clean out all the little deposits in the seals that help keep oil in the engine, so it starts to leak.
Unless it's brand new or has always had synethetic in it, stick with regular oil. Just my $.02 from experience.
Old Oct 10, 2005 | 06:40 PM
UhadMEatGT's Avatar
UhadMEatGT
Synthetics dont cause leaking or problems..............pre existing problems do. If a car is well maintained, you wont have leaks, etc.
Old Oct 10, 2005 | 07:04 PM
FWP!'s Avatar
FWP!
ORIGINAL: UhadMEatGT
False.
Don't be surprised if you start using Synthetic and start noticing you're losing oil in between changes. TRUST ME ON THIS. I've used both in many cars and cars with higher miles or that have never used synthetic before will probably lose oil. The cleaning detergents in synthetic oils are at a high concentration and clean your engine MUCH MORE than with regular oil, but this cleans out all the microscopic deposits left by dino oil that actually keep your engine from losing any. You're just going to have to trust me, I've owned 9 cars now all that had atleast 45k miles and when I was using synthetic, I would lose some and would always have to add some, if I went to a high mileage oil, I didn't lose A DROP. I take very good care of my cars and maintain the engines very well, I've replaced main seals, all gaskets, etc trying to find an oil leak while using synthetic, but I can't replace the cylinder walls or valve guides where the oil is burnt off on higher mileage engines that high mileage dino oil will not allow in most cases.
djbigskrilla
Sep 20, 2022 01:04 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Cin K
Sep 2, 2015 07:50 AM
Cin K
Aug 31, 2015 07:31 AM
jesse1125
AmericanMuscle.com
Aug 26, 2015 02:34 PM
