New problem
Old Dec 11, 2013 | 06:59 AM
Prpfire3's Avatar
Prpfire3
Default New problem
So i replaced the iac or i idle control valve i guess any ways car did fine for like 30 miles and now when i rev or run motor up while driving when i go to switch gears the rpms dont drop the stay were ever for 2-3 sec then drops to normal. What is wrong please help ever since i got my car back and trans replaced its one thing or another im fed up
Old Dec 11, 2013 | 07:02 AM
Prpfire3's Avatar
Prpfire3
Could it be i got a bad idle control valve its the thing on the valve body
Old Dec 11, 2013 | 08:44 AM
TXMach's Avatar
TXMach
I'm not sure. It may just be a mustang thing. I installed an Exedy lightweight racing flywheel which is SIGNIFICANTLY lighter than the stock flywheel and I expected my revs to drop much faster. In contrast, I noticed that the flywheel helped the engine to rev up a lot faster, but it still drops revs like a stock flywheel. I asked a few people about that and they told me that it's just the way the IAC works. But if you're noticing an even bigger delay in rev drop than you are used to, it may be something else. I wish I had more info for you. Good luck.
Old Dec 11, 2013 | 08:51 AM
96t-bird's Avatar
96t-bird
Check out the Tech articles and how to. Good basic info on your issue.
Old Dec 11, 2013 | 09:27 AM
school boy's Avatar
school boy
I have seen this several times, could be the iac is opening and allowing the idle to hang for a few seconds. someone sells the iac gasket with a smaller hole for the air to pass through. this could help.
Old Dec 11, 2013 | 11:51 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
Make sure the throttle stop screw is properly adjusted--here's how to do that.
Make sure you disconnect the battery for 5-7 minutes, one last time, after your final adjustment of the stop screw...
Old Dec 11, 2013 | 05:33 PM
Prpfire3's Avatar
Prpfire3
Ok update. So i took off the new iac and put the old back on im thinking that a got a bad iac. So only time will tell thanks for the help guys
Old Dec 11, 2013 | 05:52 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Here is how to test the IAC, I had meant to post the link earilier...
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
