Hanging RPMs...sticky throttle?
Old Apr 15, 2014 | 12:35 PM
DillonInCO's Avatar
DillonInCO
Stock I assume; it's the stock TB anyway. But the screw doesn't have any kind of slot for a screwdriver or a wrench or anything. Not sure if it's like that from the factory? I found a load of info on checking and adjusting the TPS so that's going to be my next thing to look at. I think the screw is probably OK being that it does idle fine, but then I read some things that said that if it's backed out too far it will cause this problem.
Old Apr 15, 2014 | 12:38 PM
Burtonsnow157's Avatar
Burtonsnow157
yeah try lubing the tps also with a suitable chemical im not sure what is safe. mine had a spider egg laid in it lol. also. the adjustment screw doesnt have a slot per se. . . it will have a tiny hole for an allen key
Old Apr 16, 2014 | 11:31 AM
antwaan's Avatar
antwaan
Originally Posted by Burtonsnow157
i had a similar problem to what you have. i would let off the gas and the car would stay at around 2500 rpms and drive itself like it was in cruise control and the gas pedal was sticking. this only started to happen AFTER i did preventative cleaning of the iac and throttle body so i was super annoyed but my fix was the throttle body adjustment screw - it was letting the butterfly valve/blade close almost all the way which caused vacuum lock. i turned the screw to open it up and raise idle a little bit and that solved the problem. i know you said your screw is stuck. . . is it stock or aftermarket
Mine does the same thing sometimes, only at around 2000 rpms, I can let off and it will drive itself for a good 20 seconds and then suddenly go into decel mode. Sometimes it will get stuck if I start to slow down and hit the brakes and clutch and the rpms will just stay there while I'm at the stop sign or whatever then it just drops down to normal idle rate and I take off.
UrS4
Oct 3, 2015 06:23 AM
BeatnikFink
Oct 1, 2015 08:00 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
guitarman376
Sep 30, 2015 05:54 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
