misfiring on acceleration
Hello , I just bought a 2003 gt with automatic transmission. The car only has 24k original miles and is completely stock other than the flowmaster dual exhaust I just had put on. I just noticed that when I do a " burn out " it has a miss . Does fine at first but cuts out after about 2 seconds and bogs down briefly , then catches back up. It runs great after that , even on the highway. I checked all the plugs and they seem to be firing find . At least by looks. I checked fuel filter and it was stopped up a little so I replaced it. I know there are may causes that this could be. Would just like to know which I should check first. Any helpful comments would be appreciated. Thanks
Have you tried to turn traction control off before you attempt a burn out ? And if it's missing on the highway you most likely have a coil pack going out. You need a good scan tool to pinpoint the misfire if there aren't any codes being set in the computer yet
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
Offendant
Sep 23, 2015 07:21 PM
Sep 8, 2015 11:50 AM
zanemoseley
Sep 6, 2015 12:58 PM
