I bought a set of subframe connectors. And I think I'm about to look pretty stupid. I looked under the car today to get ready to install my subframe connectors and I see what I am assuming is a subframe connector already there. The pic I'm going to attempt to post is the driver side.
The stock sfc's, if you look, don't actually connect the subframes. They would have to be longer in order to accomplish that, and more rigid as well. The stock pieces instead should be called floorpan stiffeners, because that's about all they actually do.
Ahhhhhhh thanks guys. I was going to put them on e bay or something. I bought the weld in SR sub Frame connectors from American muscle. I guess I wI'll pull off those and weld in the new ones.
Which ones did you buy; can you put up a link? Make sure when you have them installed that the shop supports the suspension not the body, trust me it will go very badly if you don't. Best if they use a roll on lift.
