Long block install questions
Old Dec 23, 2015 | 01:26 PM
WJL's Avatar
WJL
Long block install questions-picture-083.jpgI had my motor out in about six hours working at my leisure, pulled it with headers on but i have BBK shorty's.
Put it back in, in less than 3 hours
Old Dec 24, 2015 | 03:53 AM
Sandmanbjj's Avatar
Sandmanbjj
I don't see me going as quick. Hahha. That's impressive. I notice the hood is still on. I may pull mine off to make it a little easier to get at everything.
I think I have to pull my long tubes off also. However I may try to leave the transmission attached. I'm hoping that is easier.
Old Dec 24, 2015 | 07:16 AM
WJL's Avatar
WJL
I left the hood on because i did it in the driveway and wanted to be able to close it up. When putting the motor back in i had my son hold the hood open to the max and once i got it over the core support and lowered i used the regular hood rod to hold it open.
If i were in the garage i would have taken it off, good luck and keep us posted
Old Dec 25, 2015 | 02:40 AM
uberstang1's Avatar
uberstang1
Chupacabra
With my canton oil pan and mac longtubes the driver header needs to come off to pull motor out the top even with a tubular k frame. (4v)
Old Dec 27, 2015 | 08:00 AM
WJL's Avatar
WJL
After following Gary's 5.4 swap, that 4 valve is a tight fit, i'm assuming you have to take the header off from the bottom.
A 2 valve is way easier
Old Mar 16, 2016 | 08:46 AM
Sandmanbjj's Avatar
Sandmanbjj
Its been a few months. I am excited to say, the motor is finally on the way. It's in Houston and according to the tracking number I should have it today.
I ordered the long block from MMR in Dec. They had a bit of a hang up getting the stage 2 cam I wanted. So it delayed the build some.
I have everything close to ready to go for the swap. I decided I'm not going to just pull it out and replace as quick as I can. I'm going to pull the old motor, then "detail" my engine bay. Get it as clean as I can, look for and replace as much worn parts as I can while I have it torn down. I am going to change the radiator, fan and power steering pump for sure. As well as all new coolant hoses. I plan on putting a drop cloth under the car and spraying a crap load of degreaser.
I will post pics.
Old Mar 17, 2016 | 06:32 PM
WJL's Avatar
WJL
Any pics yet?
Old Mar 18, 2016 | 09:47 AM
Sandmanbjj's Avatar
Sandmanbjj
Originally Posted by WJL
Any pics yet?
The motor gets delivered today. I'm excited.
Old Mar 19, 2016 | 08:50 AM
Sandmanbjj's Avatar
Sandmanbjj
Old Mar 19, 2016 | 08:51 AM
Sandmanbjj's Avatar
Sandmanbjj
