Beginner's Tuning, etc.
Old Oct 30, 2017 | 09:23 AM
DGH1996's Avatar
DGH1996
Default Beginner's Tuning, etc.
Dear all,
I am a fairly new Mustang owner (17 y/o, have had the car for a little over a year) and I'm wanting to tune my car. I'm mainly looking for an increase in performance as well as durability in the motor and overall better specs. However, here's my issue: the prior owners said they installed high compression heads (didn't ask what specific brand, etc.) and on top of that, I also had MSD Racing Coil Packs installed as well. To sum it up, I don't know what my car is making HP wise or Torque wise. On top of this, I don't know what brands to trust in regards to upgrading the ECU, etc. Can anyone give me advice?
Thanks in advance,
Donald
Old Oct 30, 2017 | 11:06 AM
Z28KLR's Avatar
Z28KLR
The coils are irrelevant as far as tuning goes. "High compression heads".... I'm thinking that a head gasket was replaced and the heads were milled a little bit to true up the mounting surface. Removing a few thousandths or whatever of material will increase compression ratio, but only marginally.
What grade of gasoline are you using? Does it run fine (no pinging under load) on 87? If so then whatever bump in compression there is is not much of a factor.
For what you're wanting to do, a SCT or Diablo handheld device with preloaded "custom" tunes should be fine. Most of the hp gains will be noticed in the rpm midrange area, like 3-5K rpm. The advertised gains are in that section of the engine's operating range, peak gains at the top of the rpm range are typically only about 10 hp maybe.
Old Oct 30, 2017 | 11:57 AM
Buck Sergeant's Avatar
Buck Sergeant
DGH1996, Z28KLR is spot on. Call the boys at BAMA Performance : 1-888-226-9764 and tell them everything you know about your ride. I know there are other "tuning" organizations out there that are also very good. Research and then decide which company you want to use.
The ultimate tune is on the dyno "custom tuning" but I don't know if that level is what you want.
Also, you can only find your horsepower and torque on a dyno. There might be one near you locally.
Old Oct 31, 2017 | 08:59 AM
DGH1996's Avatar
DGH1996
I am using 93 (premium) grade fuel, and I rarely use 87, so I'm not sure. Should I use 87?
Also, thank you for the direction. For these specific tunings, what parts, if any, will I need to upgrade to ensure no major damage is done to my engine? I'm aware that Stage 3-4 turning requires certain parts to be replaced, which is why I ask.
Old Oct 31, 2017 | 09:01 AM
DGH1996's Avatar
DGH1996
I've also looked at BAMA tuning, and so far I haven't seen anything that goes against them (such as faulty parts, etc.)
Old Nov 1, 2017 | 07:24 PM
Z28KLR's Avatar
Z28KLR
Stage 3 or 4 tuning? Have you been on the import forums?
Refer back to post #3. Contact Bama or whoever, tell them what you know about your car, give them $400 and call it a day. No parts needed to be replaced, no tuning "stages".
Old Nov 4, 2017 | 10:12 AM
tadpole1969's Avatar
tadpole1969
take it to dyno shop , best custom tune by far
