Check Engine Light Code P1405
Old Oct 27, 2005 | 06:09 PM
baldwinsgt's Avatar
baldwinsgt
Default Check Engine Light Code P1405
Does anyone have any experience with this code. It says DPFE Sensor Upstream Hose Off or unplugged.
Old Oct 27, 2005 | 06:12 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: Check Engine Light Code P1405
ORIGINAL: baldwinsgt
Don't know exatly where it's located on the 4.6L but where ever your A.I.R tubes go (tube that connects to EGR valve) there will be a little module with an electrical connector and two hoses attached to it. Check the hoses, if they look fine, then your DPFE switch is probably defective. Very common on most Fords.
Depending on teh year, it could be covered under a TSB for free. If you check it, it looks okay, take it to the dealer and ask that the TSB be done on it (if there is one)
Old Oct 27, 2005 | 06:53 PM
DILO2001GT's Avatar
DILO2001GT
I ♥ Acer
PM Casper and ask him. He knows all about that stuff.
Old Oct 29, 2005 | 10:54 AM
Jglisson's Avatar
Jglisson
P0401 is the usual code for the DPF. It is very common on Fords, but the same code you listed leads to the same source.
The DPF are much cheaper now...I think you can pick one up now for around $20
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
