bucking problem
Old Nov 16, 2005 | 10:47 PM
00stang37's Avatar
00stang37
Default bucking problem
hey i have an 00 gt 5-spd. when im below 2k rpms in 3-5th gear and hit the gas about halfway or more my car will buck. almost like it not getting enough gas, like when you let out the clutch to fast without gas from a stop. it sometimes does it to about 2500 rpms but not as much. does anyone know what this could be? do i need a tune up and what else can i do about this. thanks
Old Nov 16, 2005 | 10:55 PM
code3GT's Avatar
code3GT
Mustang Nazi
Default RE: bucking problem
It's pretty normal.
Old Nov 16, 2005 | 11:09 PM
meebix's Avatar
meebix
It's pretty normal.
Agreed. When you let the RPM's get to low in the power gears, you will encounter some bucking as you get back on the gas. Therefore you should really be down shifting when your slowing down..
Old Nov 18, 2005 | 12:45 PM
00stang37's Avatar
00stang37
ok thanks. i didnt know if it was my injectors or fuel system being dirty maybe.
Old Nov 18, 2005 | 05:42 PM
meebix's Avatar
meebix
No problem.. If it really becomes a problem I would definitely get it checked out, because yes there's a slight jerk getting back up to higher RPM's, but if your really bucking out like the car is about to stall, get it checked out definitely.
Old Nov 18, 2005 | 05:52 PM
xx9gt6xx's Avatar
xx9gt6xx
Yep...
ORIGINAL: meebix
Old Nov 18, 2005 | 06:11 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: 00stang37
as stated above pretty normal. Look at the torque, HP curve on the car, doesn't hit it's stride until around 3K through 6k then falls flat on it's face.
mungodrums
Oct 7, 2015 04:01 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
SteelerNation82
Sep 16, 2015 07:11 AM
