upgrade advice
Just bought my 99 gt about 2 months ago and i want to put a lot of stuff in it. I was wondering what i should put in it first. Also eventually i'n going to put nitrous and a supercharger in it and I was wondering if I needed to build up my engine to be able to use them with out blowing my engine so if you guys could let me know about all that stuff it would be great.
The first mods you will see the most performance out of are either:
4.10 gears
or LT Headers. Thats if your really going for performance first.
However, if your going to be putting nitrious and an s/c in it down the road.. you may also want to check out suspension and get that out of the way first.. because that will play a key role down the road if your plan on adding major power adders.
Otherwise, for pleasing purposes.. and appeal you will be most happy with a full exhaust system.
4.10 gears
ORIGINAL: meebix
4.10 gears
4.10 gears
Im definitely not the person to talk to about suspension.. I don't know enough because I will never be putting suspension on my car because my car is based for show and not for race. Try posting a separate thread on suspension help or search the forums. I know enough about it to know that you will definitely need it with those power adders, but I wouldnt know the best brand or what exactly you would need.
Also check out the suspension packages on some websites such as mustangtuning.com and lmperformance.com
As far as suspension mods go, it all depends on what you want. If you want a car that you can wip in and out of curves, or a car that launches great for the 1/4 mile times. What you want depends on which way to go.
whatever you do, make sure you get some subframe connectors. it makes a world of difference when you make any turn. your car doesn't feel like it's going to roll over.
oh, and i hope you meant you were getting a supercharger or nitrous, not both. if you plan on getting both, then yeah, you gotta build your engine up. otherwise, you can take about 10psi with a supercharger or up to a 150 shot (125 recommended) of nitrous on your stock engine.
ORIGINAL: mustangman02232
what kind of blower would you do? if its centrifical do 4.10 gears, a roots type blower, do 3.73s. make sure you get a handheld tuner as well
ORIGINAL: nanaki
Eventually I plan on getting both ...so what kind of stuff will I need?
