Blew a strut?
Okay, My car is riding about 1/2-3/4 (guessing by eyesight and finger measurements) inch lower on the drivers front side than it is on the passenger front. I have a set of H&R Sport springs on my car, but they always seemed even to me. I noticed the car looked a little low on the drivers side a few days ago, and when i looke dover at the passenger side I was afraid I had blown a strut. I haven't hit anything, and the kicker is... the car doesn't pull.
I took it out yesterday to see if it would indeed pull (to ensure me of having a blown strut). I drove it at 25, 50, 60, 75 and even cruised for a while at 85. I had it on straight and even roads and it did not pull in either direction. I'm lost! WTF is going on here?
I have to drive home for X-mas about 400 miles, and I need to have this thing running right. I was planing on dropping in new fox body shocks and struts anyway. Will this fix my problem?
People with suspension knowledge and lowering experience on 94-04 GT's help me out!
Thanks in advance!
Ethan
Thanks in advance!
Ethan
ORIGINAL: 2000Si
Either you blew the strut or one of the springs broke... that'd be my guess.
edit: the green paint you painted your calipers with doesn't match the car color that well while you're looking at it that close.
Guest
Posts: n/a
how long has it been like that? if it broke off it could be lodged in there. I know the entire time I owned my escort one of the rear springs was broken. By the time I got around to getting all my suspension parts I sold the car. The spring just collapsed down on itself from a certain point in the coil, and it trapped the smaller broken part on the strut.
Im in the same situation as you. My driver side is about 3/4" lower than passenger in the front. I know why though... I swiped a curb during a turn last winter and bent the control arm a tiny bit. It was just enough to move the wheel back a bit relative to the body (caster). Havent gotten it fixed yet... you may want to check into that.
ORIGINAL: pete1665
I will definitely do that, thanks man. I noticed it about 4-5 days ago....
Anybody else????
No noise. Not even over speedbumps or potholes. I am stumped. A blown strut would make me pull right? And a broken spring would rattle.... I dunno what's going on here.
ORIGINAL: Emann0007
