diablo programmer question?
Old Dec 16, 2005 | 12:24 AM
thirteensecondgt's Avatar
thirteensecondgt
Default diablo programmer question?
if i get a diablo programmer......would it do me any good to get steeda timing adjuster.....is there anything i shouldnt get for my car after i get the programmer?
Old Dec 16, 2005 | 12:32 AM
dan's Avatar
dan
Default RE: diablo programmer question?
ORIGINAL: thirteensecondgt
i believe you wouldn't need a timing adjuster because you can modify the timing with the diablo. What else did you have in mind to get?
Old Dec 16, 2005 | 12:43 AM
thirteensecondgt
any and all bolt on mods...i dont even know of all bolt ons....i need some suggestions from ppl on here
Old Dec 16, 2005 | 01:31 AM
Car_Ramrod's Avatar
Car_Ramrod
check out the sticky for basic bolt on mods in the 4.6 sticky section.
Old Dec 16, 2005 | 08:51 AM
DIVER8374's Avatar
DIVER8374
^^^^ To answer that question: Yes it would do you good to get the timeing adjuster. The Diablo tuner will only allow you advance your timeing about a total of 12.5 deg's or so, and that is only at WOT. The timeing adjuster will allow you to adjust your timeing all the way to 15 Deg.'s advance as long as you don't get any detantion. '
To answer your other question, get all the bolt-on's along with your Programmer. But if you get Nitros get it put on a dyno and have them tune it, and same goes with if you get a S/C.
Old Dec 16, 2005 | 09:03 AM
xx9gt6xx's Avatar
xx9gt6xx
Programmers are very good don't get me wrong but you can't go wrong with a professional tune. That's the route I'm taking. They get your car on the dyno and diagnose the best tune/program for your applications.
Old Dec 17, 2005 | 11:14 AM
2000STANGGT's Avatar
2000STANGGT
The predator does not adjust in degrees like a timing adjuster. You want to adjust to 14 degrees and the predator adjust in decimals.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
