nitrous?
Old Dec 18, 2005 | 08:58 PM
thirteensecondgt's Avatar
thirteensecondgt
Default nitrous?
i have a 2000 mustang gt.....only mods i have right now are 4.10 gears diablo programmer and flowermaster mufflers.....it is a 5 speed gt....with 70k miles on it.....i want to just add some quick ponies....was thinkin bout gettin a nitrous kit but i dont know anything about nitrous really....would it be safe on my car? how big of a shot could i use? and does anyone know any shops in kentucky that would install and tune? and which kit should i go with? ...thanks
Old Dec 18, 2005 | 09:16 PM
2000STANGGT's Avatar
2000STANGGT
Default RE: nitrous?
I'm looking to get a shot in the future Zex has a good kit. For use on a stock motor you should be safe up to 75hp shot and it works with wide open throttle. You can get wet or dry kit.
Old Dec 19, 2005 | 11:38 PM
Jglisson's Avatar
Jglisson
I am running ZEX 100 dry...PM me for the details.
Old Dec 20, 2005 | 12:15 AM
ShadowDrake's Avatar
ShadowDrake
Zex 75 wet. Super simple install, no re-tune required, hell, you don't even need to back off the timing.
100 shot is safe, but pushing it. You will need to back the timing off two degrees. Still no re-tune REQUIRED, although it could not hurt.
125 shot is about the limit, timing needs to go back four degrees, and a re-tune could not hurt... you'll break sooner or later at a 125 shot... probably sooner instead of later.
Do not pay someone to install the Zex kit, it really couldn't get any simpler, I did it in about four hours, from start to finish. It's got a WOT switch so you will less likely screw up and spray nitrous when not at WOT... just watch your RPMs, I push the pedal to the floor to spray between 3000 and 5200 RPM or so. And you will not need a retune with a 75 or 100 shot. New spark plugs couldn't hurt, I'm using the stockers with my 75 shot though, I don't spray often.
Old Dec 20, 2005 | 10:45 PM
2000STANGGT
I always heard dry was easier to install, but you can only run 50 hp I think so the wet is better. I would like to have that 75hp.
Old Dec 21, 2005 | 12:50 AM
Plastic Fury's Avatar
Plastic Fury
Wet is also a safer way to go as it adds a fuel nozzle with the nitrous nozzle. I have a NX kit on a different vehicle and it was a very easy install and I have been very pleased with the kit for almost a year now. Just my .02
Old Dec 21, 2005 | 10:55 AM
nanaki's Avatar
nanaki
Retired MF Moderator
your car can handle up to a 150 shot completely stock. anything above that and you'll be walking (right code3gt? ).
Sandmanbjj
Aug 21, 2015 12:38 PM
mstngdvr17
Dec 25, 2003 04:55 PM
jhogan2424
Nov 5, 2003 08:51 PM
67gt500
Aug 17, 2003 04:01 AM
