Question about longtubes.
Old Dec 21, 2005 | 11:43 AM
Aixtreme89's Avatar
Aixtreme89
Default Question about longtubes.
I have BBK ceramic longtubes, and BBX x-pipe with high flow cats. Should all the 02 sensors work? Should the check engine light ever come on because of them?
I always heard that the use of an off-road mid-pipe will cause the check engine light to come on. But I dont know about the catted shorty mid-pipes.
The reason I am asking because my check engine light is on. I am going to buy a flash tuner. I want to get the SCT XCalibrator 2 but I read that I cant shut off the rear two 02 sensors, so if I have to I can't. I hope that I just have a busted 02 sensor that needs to be replaced, which is causing the check engine light on. Otherwise I guess I am going to have to buy a diablo predator tuner.
Old Dec 21, 2005 | 12:09 PM
01yellowgt's Avatar
01yellowgt
Default RE: Question about longtubes.
Get the codes read at auto zone, they should be able to tell that it isa nd find out what it is since the check engine light could be anything.
But you shouldnt have an issue with the o2 sensors with LT's and a catted midpipe. If the code that it is read is o2 sensors, it could be your extension cable going to the 02 sensors
might be loose(or maybe even burnt up touching the exhaust or cats), or just the sensors went bad. I think o2 sensors are suppose to be good for about 50k-75k miles.
I dont have LT's with a catted midpipe yet, that will be a next year thing.
For as the sct 2 you should be able to talk to the sct dealer and have them disable the o2 sensors, its probly one of those dealer options for tunes
Old Dec 21, 2005 | 12:13 PM
mustang_montana's Avatar
mustang_montana
you just have to ask the dealer to disable the 02s for you when you tell them your mods
Old Dec 21, 2005 | 02:18 PM
czwalga00gt's Avatar
czwalga00gt
Did you buy o2 extensions for the rear o2s.... they may just not be plugged in.
Old Dec 21, 2005 | 04:09 PM
racer02GTstang's Avatar
racer02GTstang
ive got a catted shorty mid pipe and i had my 02's workin with no check engine light on... could be a loose connection somewhere... now ive got my 02's turned off after i got a tune.
Old Dec 21, 2005 | 04:34 PM
Aixtreme89's Avatar
Aixtreme89
I bought BBK 02 extension wires. But the plastic quides werent lining up so I cut them off the 02 sensors. But the plug still plugs in and clips together. I ran my car about 5 starts it was fine, then the check engine light came on. Mabye the wire loosened or something like someone mentioned. I just wanted to make sure that the check engine light shouldnt be one if I have a shorty catted mid-pipe. I am going to autozone now to have my codes scanned. Then I will see what the problem is.... Thanks guys.
Old Dec 21, 2005 | 06:46 PM
Aixtreme89's Avatar
Aixtreme89
I went to autozone, I got my codes checked... I have lean situation in bank two and a problem with the cats in bank 1. I know why my check engine lights on. I have a MAC straight shot intake which replaces the stock MAS and puts it in a 80mm housing. So the computer still thinks its running on the 65mm housing. So my engine is getting more air than it knows. I am going to buy a SCT tuner and fix it... I just wanted to let you guys know incase anyone else comes into this situation.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
