slightly confused
Old Dec 22, 2005 | 08:35 PM
sandcracker21's Avatar
sandcracker21
Default slightly confused
my break light came on the other day,
so i checked my break fluid, and it doesnt seem to be low, but my mechanic said that
its probably the front pads
could this b true? the break light will come on when your pads are low?
Old Dec 22, 2005 | 08:48 PM
dlazrael's Avatar
dlazrael
Default RE: slightly confused
it could have to do with abs, take it to (i cant remember which) autozone or advance auto parts and have em read the cpu for free :-p
Old Dec 22, 2005 | 09:35 PM
sandcracker21
it only comes on when i break.....and only about 80% of the time, sum breaks it wont even come up
Old Dec 22, 2005 | 09:42 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
is it the light that comes on when you're parking break is on? sometimes the sensor goes bad. I think the sensor is right by the lever, but I'm not certain.
Old Dec 22, 2005 | 09:49 PM
sandcracker21
yes it is that light
Old Dec 22, 2005 | 10:53 PM
dlazrael's Avatar
dlazrael
My mach was doing that during hard braking, all i did was added some dot3 to the "max fill" line and it corrected the problem...
and also... barring the sensor being bad...
why would the mech say the FRONT brakes, last time i checked, the parking brake was associated with the REAR brakes...
Old Dec 23, 2005 | 04:42 AM
sandcracker21
ill try to fill it up a little bit with the fluid, even tho it looked quite full when i first checked it
the light only comes on under heavy breaking, but will come on under light breaking SOME of the time
has this happened to anyone else?
Old Dec 23, 2005 | 11:46 AM
Miliock's Avatar
Miliock
yes, that will happen under hard braking when your pads are worn or when the brake fluid is low. How many miles do you have on your car? Prob time for some new pads.
Old Dec 23, 2005 | 01:24 PM
mustang_montana's Avatar
mustang_montana
my ebrake lights been on bout 6 months now. i dont pay attention to it. the sensor is messed up. when i took out the center console on numerous occasions, i messed it up.
Old Dec 23, 2005 | 02:12 PM
sandcracker21
ORIGINAL: Miliock
i have 23K on it
