car died, help needed
Old Dec 23, 2005 | 01:39 AM
xkon's Avatar
xkon
Default car died, help needed
well i went to get some food with my friends, the car was running perfectly fine...when i came out, i started the car up, and the rpms kept jumping from 400-700 back and forth at idle. I took it up to the gas station and filled it up. It felt like it was draging when first accelerating. When i turned the car on(it started), the tac didnt go up at all and it died. I had to constantly give it gas, even when braking so it wouldnt turn off....could this possibly be the alternator? thanks for your help
Old Dec 23, 2005 | 01:41 AM
xkon's Avatar
xkon
Default RE: car died, help needed
forgot to mention, i also left my interior light on when i was eating...it was only about an hour though
Old Dec 23, 2005 | 01:43 AM
01yellowgt's Avatar
01yellowgt
Sounds like the Idle air control valve (IAC). Pull it off and try cleaning it out with some carb cleaner, and spray some wd-40 in it.
Old Dec 23, 2005 | 01:44 AM
racer02GTstang's Avatar
racer02GTstang
check your fuel pump... sounds like it may be short on fuel and the motor could be cut off. wait, nevermind.. just read the rest of the post... could be altenator, or regulator. something of the sort.
Old Dec 23, 2005 | 01:48 AM
xkon's Avatar
xkon
i dont know too much about everything under the hood, where exactly is the IAC located?
Old Dec 23, 2005 | 01:52 AM
01yellowgt's Avatar
01yellowgt
Its on the plenum(has the mustang on it), look on the front side of that. there little thing connected to it, with a hoses and what looks like a electric motor
Old Dec 23, 2005 | 01:58 AM
xkon's Avatar
xkon
alright thanks, im gonna check that out in the morning, hopefully that is it... btw your CAI looks awesome yellow
Old Dec 23, 2005 | 02:05 AM
01yellowgt's Avatar
01yellowgt
any time, let us know if it works or not. But sounds like the problem. Thank you for the complement.
Old Dec 23, 2005 | 02:19 AM
sdsjr4's Avatar
sdsjr4
sounds like iac or alternator! If it's the alternator everything will shut down and the car will not even turn over!
Old Dec 23, 2005 | 02:58 PM
xkon's Avatar
xkon
i went to look for the IAC today, and my intake tube had come undone...maybe when i took my car in to the dealership for them to inspect my intake manifold they did something? either way i tightened it back up and its running fine now
