Manual Transmission
I have a 2003 Mustang GT, i'm assuming that means i have the 3650 tranny then...
Alright, i was taking off in first gear, just a casual take off, nothing real fast, then the tranny makes a loud loud pop and comes out of gear. It was all the way in gear for sure when i took off. I tried to get back into first with no luck... The next day, it let me back into gear a few times, but not usually.
I took it up to the dealership as I have a ford extended warranty. While the technician drove it, it went into gear fine. He stated there was nothing wrong with it. What should I do??????
Thanks
Thanks
Drive it and if its working fine now just keep an eye on it. If it does it again and I assume its under warranty, I would go back to the dealer and tell them to fix it right. Sounds like the shifte isn't getting the car all the way into gear. Out of adjustment?
1997 Rio Red Cobra Coupe
Kenne Bell Supercharger at 7PSI
Kenne Bell Open House Hi Flow Manifold
Kenne Bell Boost a Pump
Superchips Excalibrater II Tuner
MSD Blaster Coil Packs
C&L TrueFlow Inlet Intake Power Pipe
Super Chips MAF with K&N Filter
UPR O/R x pipe
MagnaFlow Catback Exhaust
Bilstein Shocks and Struts
Kenny Brown Sport Springs
Kenny Brown Extreme Matrix System
Kenny Brown Rear Shock Tower Brace
Kenny Brown Lower Chassis Brace
Kenny Brown Caster Plus Kit
Steeda Lower Control Arms
Lakewood Upper Control Arms
Ford Racing Aluminum Drive Shaft with Safety Loop
T/A Rear End Girdle
B&M Pro Ripper Shifter
Autometer Guages
Raptor Shift Light
Hood Struts
Rear quarter Sail Panels
Side Scoops
Custom Striping
275/17 X 9†Front 315/17 X 10.5†BFG drag radials Rear on Cobra R Rims
UPR O/R x pipe
T/A Rear End Girdle
Autometer Guages
Raptor Shift Light
Hood Struts
Side Scoops
Custom Striping
"Alright, i was taking off in first girl, "
Did not know stangs came with girls!!
LMAO yeah take it into the dealer and if you have a warranty they should fix it. It sounds to me like the shifter is out of adjustment or the shift mechanism inside is not locking when it should.
George
George
ORIGINAL: MichelleBeMyGT
lol, i edited the "girl"...
it has 37,000 miles on it so i didn't think it would be a clutch issue, but it may be time for a clutch
is there an easy way to determine if the clutch is about to go???
BeatnikFink
Oct 1, 2015 08:00 PM
