USED, gears?
Old Jan 13, 2006 | 02:38 AM
GIGM08GT's Avatar
GIGM08GT
Default USED, gears?
so I bought my car used, i still love it. Anyway I dont know what gears it has in the rear end and dont wanna buy new ones if it already has upgraded gears. Is there a way to check?
Old Jan 13, 2006 | 02:41 AM
Aixtreme89's Avatar
Aixtreme89
Default RE: USED, gears?
As long as you know what rpm your car stays at in a certain speed you can figure out what your gear ratio is. Just fill out the info on this web page and you will know.
http://www.tchracing.com/tech/gearcalc.php
Old Jan 13, 2006 | 02:48 AM
racer02GTstang's Avatar
racer02GTstang
what rpms are you at in 5th gear at 70? that will give you a good figure. or even at 60. and someone on the forums can tell ya what they are at... at 70 im like at 2200--2300 and when i was stock gears i was at like 1900-2000. ive got 3.73's.
Old Jan 13, 2006 | 02:51 AM
gt96stang's Avatar
gt96stang
1.Raise the rear of the car. Then as you turn one of the rear wheels, count how many times the driveshaft turns. IE 3 1/4 turns=3.27 gears(STOCK), 3 3/4=3.73's... and so on.
Old Jan 13, 2006 | 02:55 AM
Dark_Horse's Avatar
Dark_Horse
jack up the rear of the car...
marke the drive shaft longways with chaulk, like a 1" or something
rotate your tires and see how many times it rotates if the drive shaft rotates a little over 4 times then you have 4:10 gears if it rotates less then 4 but almost, more like 3 and 3/4 times then you have 3.73s if you rotate and the drive shaft it a little over 3 spins about 3 and 1/4 times then you have 3.27s(Stock on most GT) if it rotates 2 and 3/4 times then you have 2.73s(or something like that, i think i cam stock on a few im not sure)
mine came with 3.27s and i put in 3.73s
Old Jan 13, 2006 | 02:56 AM
GIGM08GT's Avatar
GIGM08GT
this site worked great thanks i remembered at 2000 is when Im at 70 in 5th, turns out I do in fact have the stock gears. Well I know whats next
Dark_Horse's Avatar
Dark_Horse
gt96stang
you beat me to it, i was typing
Old Jan 13, 2006 | 04:13 AM
Jiggy_One's Avatar
Jiggy_One
4.10's, you will regret getting 3.73s. Or better yet, 4.30's. Trust me.
Old Jan 13, 2006 | 10:29 AM
n/a_threat's Avatar
n/a_threat
ORIGINAL: Aixtreme89
That isn't quite true. I have 3.55 rear end (for now), but before I installed my headers I was running 75 mph @ 2500 rpm, now with less restriction, I'm running 75 mph @ 2000 rpm. I wasn't expecting my rpms to drop, but they did.
I'd listen to the quys about rotating the wheels while the car is off the ground.
Old Jan 13, 2006 | 10:34 AM
nanaki's Avatar
nanaki
Retired MF Moderator
i doubt he has LTs or something in there. he'd know it if he did, and not based on his RPMs.
