Looking for more horsepower.
I got my car dynoed i made 275rwhp and 292rwtq. I want more. I really want to break 300rwhp. I bought underdrive pullies but I cant install them because I stripped some threads on my crank, so thats out of the question until I get a new short black. I dont want nitrous or supercharger yet, or I dont want an offroad pipe. What do you think it will take to make it? Or I dont want to port the heads yet. What do you think it will take? I was thinking mabye going to a smaller diameter CAI will help, I have heard 85mm MAF is way to big. Also do you think an intake manifold like the P-51 or bullit will do it? Thanks.
ORIGINAL: Matts00GT
I don't think you can get much horsepower out of it, unless you go with nitrous, blower, or ported heads. You are close the max bolt on limit. Not much else you can do.
yea hes right, the only thing u can do is get a non catted x or h instead of the catted system for hp and do some weight reduction, get drag springs and radials. that will give u a better 1/4 thats about it. if u want more power your going to have to go with a sc and/or nitrous. im in your same position, im trying to get my car to run low 13s maybe high 12s with out a sc or nitrous.
ORIGINAL: G2000T
ORIGINAL: Matts00GT
Also I heard that the high flow cats are so advanced now that I only lose about 1-3hp by having cats. Really not worth it to me if thats the case, I like the sound with cats, I dont like the raspiness with out the cats.
I could tap my crank, but I would have to drill out out and tap it with a larger bolt. But ford uses metric with about everything and its very hard for me to find a metric grade 10.9 bolt. Plus thats kinda risky, I have one shot. Or I could use a helicoil, which you drill and tap with a larger side and then put new threads in and its back to the original size, but I dont think they can withstand the 65ftlbs the harmonic balancer needs. So I have been told.
Its kind of wierd that each car is so much different than the next. One of my friends has the same exact mods as you except VT stage 1 cams and he dynoed at 292 rwhp. I dont really have any other ideas for you though, it seems like you pretty much have everything before going FI.
ORIGINAL: spederman
