How to calibrate Speedo? HELP!!!!!!
Should look into doing it soon since your adding excessive mileage too. I would get the Predator tuner becuase it does so many other things as well, and those speed calibrators I belive cost around 75-100, kind of a waste to me.
ORIGINAL: 98GTstang
I heard that the tuners wont tune a 98 mustang gt's speedo..is this true?
did you check with the place where you got your gears installed to see if they possibly had a speed calibrater? When i was looking into gears for my 98 when I had it, the place i was going to get them installed at said they could calibrate my speedo for me if i got them installed there.
me and a buddy installed the gears, i called ford racing and they said the only way to get the speedo accurate was to replace the speedo gear inside the tranny..but will a speed calibrator (speedcal) work?
ORIGINAL: 98GTstang
