Headlight help
Old Jan 20, 2006 | 02:01 PM
GTnAZ's Avatar
GTnAZ
Default Headlight help
Ok so I need some help figuring out why when I am driving down the road and hit the small bumps or cracks in the road my headlights shake like they are not mounted tightly... the little pins that hold them in are all there and the little 'humps' that hold it tight are good... can anyone help me out in what to look for or try next?
Thanks!
Old Jan 20, 2006 | 02:09 PM
pj1010's Avatar
pj1010
Default RE: Headlight help
Perhaps the filaments inside the bulbs themselves are causing this. Even a small move in a filament would result in a drastic shift in the direction of the light exiting the lamp cover.
Old Jan 20, 2006 | 02:42 PM
GTnAZ's Avatar
GTnAZ
i dont think its that.. the bulbs are only like 3 months old and they are the sliverstar bulbs... so i would guess they are of good quailty... when i kind of hit the front bumper with my first... and i am parked in front of my garage... it does seem like its the buld that is loose... and i have made sure the little fitting on the back of the bulb is tight and everything is connected right... so i am clueless here...
Old Jan 20, 2006 | 02:53 PM
pj1010's Avatar
pj1010
So...you hit the bumber and it looks like the bulb itself is shaking?
Old Jan 20, 2006 | 02:58 PM
justingt's Avatar
justingt
maybe the gasket between the headlight housing and the bulb is damaged
Old Jan 20, 2006 | 03:18 PM
StickShifty's Avatar
StickShifty
there is a round black plastic ring that holds the flange on the back of the bulb to the light housing. that may be in back-wards. and not keeping it tight.
Old Jan 20, 2006 | 04:54 PM
GTnAZ's Avatar
GTnAZ
ORIGINAL: pj1010
Yes
ORIGINAL: StickShiftyGT
Yes there is the black ring... and from what i can tell, you can only put it on one way... there is a 'deep' side and a 'shallow' side... the only way it goes on and holds the bulb in place is with the shallow side... but i will check it again and make sure it looks ok...
And another way for me to expalin the light bulb vibration is when you hit a bump or crack... the little rattle that you might hear inside your car of any plastic part... if you hear that rattle... the way the rattle sounds is the exact same way the light vibrates... i dont know if that will help you pin point anything else that might be wrong...
Thanks for all the help thus far!
Old Jan 20, 2006 | 05:00 PM
code3GT's Avatar
code3GT
Mustang Nazi
Dude, I am clueless. Wish I could help, but please post up results.
Old Jan 20, 2006 | 11:39 PM
kasper's Avatar
kasper
Pull the housing out and check all the tabs to insure none are broken. There are small tabs that keep the housing in place. It is possible that one are more have broken off and is causing the problem you are experiencing.
Old Jan 20, 2006 | 11:45 PM
StickShifty
ORIGINAL: kasper
that prob wont do it, cuz my tabs are all cracked off, lol. yea they break very easy when its 5 degrees outside.
