5.1 Stroker
I am building a N/A 5.1 stroker with about 10.8-1 compression I have Patriot stage 3 heads and I have comp cams 270 I also have a canton windage tray I have 24lb injectors and 75mm tb with plenum and a gms mass air I also have underdrive pullys and i have full exhaust and a diablo preditor tune what kind of power should i be looking to make and is this a good combination, and soon I will change out the fuel pump and put a 150 wet shot on it
good point... and why do you use "and" so much man?? j/k
ORIGINAL: 04BlueGT
Is the bottom end forged and what does the manufacturer rate the stroker kit at? And why the stage III heads with what is essentially stage II cams?
ORIGINAL: Philip
That is one long A$$ sentence. Good luck with the Patriots. As someone else asked, "is the bottom end forged"? I would ditch the MAF, just use the stock one, it will work fine. "I" would think about bumping the injectors from 24# to 30#'s. Just my 2 pesos.
because you will be making more power then a stock 96-98, 99, or 01 cobra with full bolt ons, heads and cams, ecspecially with the extra cubes.
I am betting you make 340+ to the wheels on a conservative tune.
lol jk
