Positracktion
Old Feb 10, 2006 | 05:35 PM
06mustang88's Avatar
06mustang88
Default Positracktion
ok, i have a 98 gt conv. and really want to lay 2 sets of rubber. can anyone help me with this? how hard is it to put a posi in? which kind should i buy? how much am i looking at spending after instillation and everything? thanks
Old Feb 10, 2006 | 05:37 PM
Emann0007's Avatar
Emann0007
Default RE: Positracktion
my 97 lays 2 strips of rubber
Old Feb 10, 2006 | 05:38 PM
MustangMafia's Avatar
MustangMafia
I considered getting a posi too. Do you think the shop would charge any more to install this if I get it installed the same time I get gears installed?
Old Feb 10, 2006 | 05:39 PM
codyss's Avatar
codyss
Ford's version of Positraction is called Trac Loc.
Your GT should allready have a posi differential in it, it might be due for a rebuild.
Ford sells a kit that isn't very expensive but you will need to know how to remove the carrier assembly and how to replace the clutch packs.
Old Feb 10, 2006 | 05:40 PM
demon_head's Avatar
demon_head
I lay two sets of rubber in my 96.....gt's come w/ limited slip (pretty much the same thing as posi) so you should be able to. Your clutches in your differential might be worn out.
codyss's Avatar
codyss
All GT's after the 90's should have Posi standard.
I think your guy's need to be rebuilt.
Posi = Limited Slip
Old Feb 10, 2006 | 05:46 PM
Dsmfighter's Avatar
Dsmfighter
"Hows positraction work in a plymouth... nobody knows.... IT JUST DOES"
-brought to you by your friend Joe Dirt.
Old Feb 10, 2006 | 05:52 PM
MustangMafia
ORIGINAL: Dsmfighter
It was actually Joe Dirt's dad that said that wasn't it?
Old Feb 10, 2006 | 05:54 PM
MustangMafia
Any how about a spool diff? Anybody ever seen one of those for a late model Mustang?
Old Feb 10, 2006 | 06:03 PM
Sidewayz6.0's Avatar
Sidewayz6.0
I've seen a mini spool done in a late model.
