2 Problems
My 1998 Mustang GT 5 Speed has 2 problems im a little concerned about.</P>
First of all:</P>
Sometimes, shifting into 3rd gear, it grinds. Its only been 3rd gear and im not doing anything wrong; clutch is fully depressed and whatnot. Im afraid the grinding is going to cause i bigger problem. Does anyone know what the problem is or if a short throw shifter can help</P>
Secondly:</P>
When taking a corner hard or long, the rear end of the car makes a dry, rubbing noise. Its coming from the rear of the car, I have no payed much attention to that but more details will be on the way</P>
Thanks Alot</P>
I had the exact same problem with my car. I hate to say it, but you have a bad syncro for the third gear, and if its been doing the grindind for more than a few days, you also will need to replace third gear. I had mine repaired, and the warranty total was a few dollars over $1000, but of course thats the dealership cost. Mine started this problem when I was using the short throw shifter, so adding one will do nothing for the problem. Good luck..
I dunno if this will sound stupid to you or not, but today i tried double clutching 3rd gear, and no grinding at all. Right now i dont have 1 g to spend on my car since im a high school student with a tight budget but i had a feelin it was the syncro. Thanks Alot for the advice, i appreciate it</P>
Originally Posted by NO2JUNKIE
hotrodman, you are staring to sound like hang10, a lot of post whoring<IMG src=smileys/smiley11.gif border="0">
