This looks much better
Looks alot better. I have never used those big dumbo ears either. I just did mine too, along with disabling the damn seat belt reminder
Hey Spro why are your headrests different than mine? That's weird, I thought they were all the same.
They must of changed the headrest in 04 for some reason.
Heres a write up on how to dothis thanks to smooth_J
http://www.mustanghowto.com/interior...t/Headrest.htm
ORIGINAL: wgdt21
I want to remove mine too. Was it hard? Is therea write-up somewhere?
ORIGINAL: Jaybird79
It's easy. You don't need to remove the headrests at all. Basically I just raised then up as high as they'd go, then angled them forward, and then used a hex key set to unscrew the two bolts that hold the plastic piece on the seat. Taking the headrest out would probably make it easier, but I left them in and did it.
ORIGINAL: wgdt21
Ijust took one of them off, butI sort of stripped the other one and can't get it off, it started to **** me off so i stopped for tonight. My hex key didn't really fit either. grrr, thats really going to annoy me[:@]
