Defroster problems
Old Jun 29, 2007 | 02:51 PM
Silver714's Avatar
Silver714
Default Defroster problems
I understand that the a/c will create a certian amount of pull on the engine with the defroster turned on. Mine seems excesive. On a rainy day like today, I'll use the defroster to keep the windshield from fogging up. With the defroster or the a/c on the car jerks hard like a missing cylinder or maybe even a little harder than that. Pulling up to a stop in neutal the tac will drop nearly to 0 then the computer will compensate and shoot the rpms to about 1800. It doesn't do this on dry hot days running the a/c. Some but barely noticeable- only when it is damp out. I'm guessing it must be some sort of sensor problem but I'm really pretty clueless as to which one or am I totally off the mark alltogether?
Old Jun 29, 2007 | 02:55 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: Defroster problems
ORIGINAL: Silver714
Is that when accelerating?
The screwy RPM at idle and decel is probably the Idle Air control lagging. Pull it out, clean it, put a new gasket on it and slap it back on.
Old Jun 29, 2007 | 03:06 PM
Silver714's Avatar
Silver714
Accel and deccel. It doesn't seem to make any difference what the rpm range is either. I tried about 3000rpm steady in 1st gear and it was jerking then too...
Old Jun 29, 2007 | 03:18 PM
Silver714's Avatar
Silver714
Thanks Derf00. I'll give that a shot.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
