Bore it
Old Jul 1, 2007 | 04:58 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default Bore it
So, which bore and stroke combo would you like best for our 280-290cid V8's?
Code, thanks for the poll option...I get the first poll, where's my cookie?
Old Jul 1, 2007 | 05:02 PM
POISND U's Avatar
POISND U
Default RE: Bore it
I was under the impression our cylinder walls were too thin to get a useful bigger bore, no?
Old Jul 1, 2007 | 05:07 PM
Colorado_Mustang
Default RE: Bore it
Make your own block. No small block, and I doubt any big blocks, can accomodate a 4.5" bore. But, that's not the question. The question is which would YOU design.
Old Jul 1, 2007 | 05:17 PM
avlon06's Avatar
avlon06
Default RE: Bore it
i wish i knew exactly what yall were talking about.. lol
Old Jul 2, 2007 | 04:04 AM
Hyper00's Avatar
Hyper00
Default RE: Bore it
ORIGINAL: avlon06
Me too. Jeez...make it like chosing a president why don't you.
Old Jul 2, 2007 | 11:48 AM
oxfordgt's Avatar
oxfordgt
Default RE: Bore it
I'd say none of the above. You will have torque like a 4 cyl with all of those except the 3.55x3.55 which is only .01 bigger in the stroke then stock.
Old Jul 2, 2007 | 10:56 PM
droptoppony's Avatar
droptoppony
Default RE: Bore it
A 4.0 bore would be great on a modular!
A Big Bore from VT or Modular Performance is only 3.7 and thats about the max our blocks can go so i'd like to see the next generation have atleast a 4.0 bore.
Old Jul 3, 2007 | 12:20 AM
avlon06's Avatar
avlon06
Default RE: Bore it
by boring it out does this mean increasing the size of the engine as in 281 to what ever u bore it out to?
Old Jul 3, 2007 | 12:59 AM
Colorado_Mustang
Default RE: Bore it
Depends on the stroke. Each of those combos are similar in final cubes, even though each will act differently. The top two combos are real engines (289, slightly destroked and 4.6L), the other two aren't.
Larger bores = larger valve area = more air flow = more power
Short strokes = less low rpm torque = more high rpm power
McLeary
Mar 14, 2016 07:50 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
JayGee
Sep 15, 2015 12:41 PM
FivePointToTheOh
Sep 14, 2015 03:35 PM
Faolan65
Aug 27, 2015 06:40 AM
