to much or not enough
Old Jul 13, 2007 | 10:24 AM
xander0561's Avatar
xander0561
Default to much or not enough
ok so I went to the track last night , the best I could do was a 15.054 @ 94.4 MPH. [:'(]I can't get the car to launch at all. It will either bog out or spin the tires, and seeming that the "awesome " limited slip isn't really working I don't think I'll ever have good launches. sigh. 2300 RPM and less it bogs and 2300 and more it spins. [:@]
Old Jul 13, 2007 | 10:52 AM
DragonOfBC's Avatar
DragonOfBC
Default RE: to much or not enough
What was your 60' time? What tires do you have?
Old Jul 13, 2007 | 11:02 AM
H0SS302's Avatar
H0SS302
3.08 gears FTL on that one
Old Jul 13, 2007 | 11:12 AM
sunguf's Avatar
sunguf
Yeah why do you have 3.08's?
Old Jul 13, 2007 | 03:27 PM
xander0561's Avatar
xander0561
i do alot of highway driving so I kept the stock gears. and my 60ft times were 2.13 and I have falken tires with 24 lbs of air.
Old Jul 13, 2007 | 03:38 PM
CobraStangGT16's Avatar
CobraStangGT16
hmm...your 60ft isn't too bad...if you can get it down to 2.00, that would help alot.
But those gears are holding your car back...ALOT. If you get the 60ft lower, I think you can make it into the 14's. The PI swap should have put you into the high 14's. I think it's just the gears. A set of higher gears will getyou to the 60ft in much less time. Good luck!
Old Jul 13, 2007 | 03:46 PM
P Zero's Avatar
P Zero
Stop trying to "launch" with street tires. Ride the clutch just a tad longer as so not to let the car bog out.
-P.
Old Jul 13, 2007 | 03:54 PM
xander0561's Avatar
xander0561
thanks for all the input guys, I really appreciate it. I will try again when I go out to BMP on the 22nd. And will repost and let you know how it went.
