My best on 275 street tires...2.066
My best of 315 nitto drags... 1.77
You shouldn't have any problem getting your 60ft in the 1.8-1.9's.
What psi did u run yours at.Im hoping for 1.7's 60' myselfbut 1.8's wouldmake mehappy for now.After i get the hang of it with the dr.I think i could pull a 1.7X 60' being i went 2.022 on cheap sumi tires
I've run anywhere from 17psi to 20psi when I go to the track. With the nitto's, you can actually go to low on the air pressure. I would start out around 17psi because the heat will raise the air pressures up a lil once you do your burnout.
For me, I had better results doing a 2nd gear burnout rather than a 1st gear burnout. On a 2nd gear burnout, I was able to slip the clutch hard at about 3-3.5k rpms without too much spinning at all. It depends alot on the track conditions too tho.
