IRS to a solid rear
Old Aug 1, 2007 | 12:04 PM
Hulk99's Avatar
Hulk99
Default IRS to a solid rear
Well, I've been inspired by some of the sweet rides on this site and have decided to turn the cobra into a straight line car (since the two tracks nearest to me are drag strips) Anyways, right now I'm kinda poor, but would like to get started on the car by getting rid of the IRS. I was told that the solid axle would bolt right in, but what other items will I need? Upper and lower control arms? I want a setup that will handle 700+rwhp so I'm assuming 31 spline axles will handle that? or do I need to go beyond the 8.8 solid rear axle? And last but not least price? any ideas? Guessing $1500.00 in parts?
Old Aug 1, 2007 | 12:09 PM
xander0561's Avatar
xander0561
Default RE: IRS to a solid rear
I have no idea if it can be changed, but if I were to change axles around I would go for a ford 9"
Old Aug 1, 2007 | 12:13 PM
Hulk99's Avatar
Hulk99
ORIGINAL: xander0561
An 8.8 will supposedly bolt right in. How much stronger is the 9" ?
Old Aug 1, 2007 | 12:22 PM
xander0561's Avatar
xander0561
well it's set up conpletely different. the career and gears are in something called the "third member" and it is bolted to the front. I'm pretty sure that the splines and axles and everything is much much stronger.
http://www.currieenterprises.com/
They can send you exactly what you need.
Im sorry Im not an expert in this area, but I do know that those rearends take the punishment really well.
Old Aug 1, 2007 | 12:45 PM
mex69's Avatar
mex69
ill trade you
Old Aug 1, 2007 | 12:53 PM
Hulk99's Avatar
Hulk99
ORIGINAL: mex69
ill trade you
Where are you located?
Old Aug 1, 2007 | 02:05 PM
ShadowDrake's Avatar
ShadowDrake
Hulk, where are you loctaed? I'll GLADLY make the trade, and can drive and do the work to make the swap if you're relatively nearby
Old Aug 1, 2007 | 02:52 PM
Pest007's Avatar
Pest007
I'll swap you if your in AZ!!
Old Aug 1, 2007 | 03:44 PM
Hulk99's Avatar
Hulk99
For anyone interested in swappingI'm located between Baltimore and Annapolis in MD. If I do end up just buying a new rearend, the IRS will certainly be put up for sale on this site.
Old Aug 3, 2007 | 07:48 PM
mex69's Avatar
mex69
sorry about the long wait but i live in tejas i think thats a lilto far from balitmore haha
