cams
Old Aug 6, 2007 | 11:31 AM
96GT_PSL's Avatar
96GT_PSL
Default cams
i see everyone talk about the VT cams. how about comp cams? MM&FF seem to love these cams. im looking into getting some. any suggestions?
Old Aug 6, 2007 | 11:56 AM
03greyGT's Avatar
03greyGT
Default RE: cams
Either brand is good. I chose to go with VT cams because they do not have any advance ground into their cams. Comp grinds about a 5* advance into their cams, therefore you need to degree them on a stage 2 and 3, so there will be PTV clearance if not degreed. Also, with a PI swap like you have, if your doing PI cams, the PTV issues will be even more of an issue. Either way though, there both respectable companies...
Old Aug 6, 2007 | 12:40 PM
Chris98Gt's Avatar
Chris98Gt
Default RE: cams
I've got compcams stage2's I think there 268ah, with full pi swap and I was only out 2* on the drivers side with no degree wheel. But I did have to use the cam followers from the 98gt heads so there was no ptv issues.
Old Aug 6, 2007 | 03:33 PM
yelw02GT's Avatar
yelw02GT
Default RE: cams
yeah i went with VT as well, good products for the modular engines, ill take VT over comp all day
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
