Motive 3.90 gears?
Old Aug 7, 2007 | 10:58 AM
Hulk99's Avatar
Hulk99
Default Motive 3.90 gears?
I know some of you guys are sporting the motive gears, what are your thoughts on them? Are they as good a Ford racing? Most importantly will I need to worry about gear whine?
Old Aug 7, 2007 | 11:03 AM
wgdt21's Avatar
wgdt21
Default RE: Motive 3.90 gears?
no gear should whine when installed properly. I'd go for it.
Old Aug 7, 2007 | 12:02 PM
jpmustanggt's Avatar
jpmustanggt
I have motive 4.10's, they are fine as long as they are installed properly.
Old Aug 7, 2007 | 12:48 PM
jsmarsh25's Avatar
jsmarsh25
i have motive 3.90's in mine. no whine, run great. plus u can't get 3.90's from Ford Racing, so you're kinda limited on your selection if you're set on the 3.90's
Old Aug 7, 2007 | 01:01 PM
nathansee3's Avatar
nathansee3
I have heard alot of good things about motives. 3.90's nice choice. GO for it.
Old Aug 7, 2007 | 01:13 PM
DesertMach's Avatar
DesertMach
Agreed, a proper install should have no whine..
Old Aug 7, 2007 | 01:16 PM
langod's Avatar
langod
I've had Motive 3.90s for 2 years. No problems, no whine.
The most important thing is having them properly installed. Make sure that whoever you get to do it has done gears LOTS OF TIMES before. IT's no job for a beginner.
Old Aug 7, 2007 | 01:17 PM
Hulk99's Avatar
Hulk99
Great, thanks guys just ordered them, the master bearing kit, 3qts royal purple, a rear seat delete, and a car cover to keep it all looking good.
Old Aug 7, 2007 | 02:01 PM
leglocking101's Avatar
leglocking101
I have heard (from a friend) that replacing the gears can cause vibration in the driveshaft???
anyone have any confirmation on this
Old Aug 7, 2007 | 02:06 PM
MustangChris04's Avatar
MustangChris04
there may be vibration in the driveshaft when your on the highway and you let off the gas, when accelerating or cruising you won't feel it, but as soon as you let off the gas there will be vibration. I think an aluminum driveshaft will solve this.
