PB blaster
what does it do? is it much different than WD-40? because i'm having the most hellish of a time getting my pass. side midpipe bolt off and i heard use PB blaster, but i'm already using WD-40 on it and wondering if it would make anymore of a diff. the WD-40 would. also where to buy it?
yeah i tried using the breaker bar, after i was pushing as hard as i can and it came back slamming into my ribs i kind of said f*ck that haha, but i'll try the bar again, i think my main problem is clearance issues with my elbow, and i can't even see the threads on the end of the stud it's so rusted[:@]
PB actually eats through the rust. It's a lot better than WD-40 and much quicker. I use it all the time at work. However, if they're really rusted and stuck, you might need to torch them. I do at work, at least.
ORIGINAL: Xemeth
PB is like WD-40 on steroids.
yah that's what i was trying to use earlier, my main problem is the stud is covered in rust- can't even see the threads really, so i really need something that will eat up the rust so the bolt can actually move on the threads
PB blaster works great for problems like that......i had to put some on my ****ing hood latch the other day b/c it got stuck open....so when i closed my hood, it just bounced of it and didn't latch
[:@][:@] damnit[:'(]
