Professional Products Plenum and TB
I am thinking about getting this combo. I am worried about my car not running right due to air/fuel ratio being incorrect after the install. Is this valid, will I need a tune after? Should I do it myself or just have the shop were I got my gears installed do it?
An aftermarket TB and plenum will not affect a/f ratio, the PCM takes care of that. You will want to discomment the battery for 5 or more minutes after installing them to cleat the KAM (Keep Alive Memory). This is nostlyso that the computer can relearn the idle speed, however it will also reset the long-term fyuel trim values. [/align][/align]I have the Pro Products TB & plenum and am quite pleased with same...[/align][/align]
[/align]
[/align]
ORIGINAL: cliffyk
[/align]
[/align]
ORIGINAL: jrherald420
hey cliffyk im going to get the tb/plentum combo also what size tb did you get 70mm or 75mm?
why does everybody insist that a 75mm is bad for an NA car? and FYI, a TB/plenum doesn't even add much power for blown cars either. i picked up a whopping 6RWHP.
i love doing mods with a before and after. this way i know just how full of crap manufacturers and some people making up numbers. found out how much the tb/plenum really adds, how much my meth kit added, and how much long tubes added when my car was already built and blown.
