hey i may want to take out the isolators on my car....i have the pro kit right now but i want jsut a little bit lower...how much will it lower it if i do this, and how will the ride be, ive heard its alright and theres no noises
I've got the FRPP "C" springs and I removed both front and back isolators. It should give you between 1/4" and 1/2" more drop in front. Not much in the back tho. No noises here either.
awesome, its just kind of a big job to take all that **** off just to pull off the isolators tho
The ride will q will suffer a bit, but it will lower the cars and xtr 1/4" or so. I use to spray the rubber undercoating on the spring pockets to quite it down the ride some, worked pretty well.
I heard no noise from the front but the back passenger side is making some clunking noise when u hit bumps.I may try that undercoating tip was that mentioned.
Here's an idea.... Take of the bottom boot of your front springs and put it around the lower coil of the back springs. It can only be about an 1/8 - 1/16th of an inch thick while compressed but would still act as a noise reduser.
