What else do i need?
Old Aug 29, 2007 | 02:55 PM
BADSEED's Avatar
BADSEED
Default What else do i need?
this winter if all goes well i will be be purchasing a set of stock 02 GT heads and installing it in my 99 and since in there i was thinking about going with a stage 2 cam from VT, if i i was to get the stage 2 cams what else would i ahve to upgrade?
Old Aug 29, 2007 | 03:04 PM
mvr's Avatar
mvr
Default RE: What else do i need?
i know you need valve springs
Old Aug 29, 2007 | 03:13 PM
ZW99GT's Avatar
ZW99GT
Why would you put 02 heads on a 99? Are yours damaged or something?
Old Aug 29, 2007 | 03:15 PM
mvr's Avatar
mvr
oh, while you have the heads off pnp them
Old Aug 29, 2007 | 03:21 PM
BADSEED's Avatar
BADSEED
ORIGINAL: ZW99GT
Alot of guys have been telling me that the 02-04 GT heads raise the compression in the 99-01 GT and give it around 70HP i didnt believe it at first first and then i started asking around and a couple of guys to me that it actually works
Old Aug 29, 2007 | 03:25 PM
BADSEED's Avatar
BADSEED
ORIGINAL: mvr
How much would that cost?im trying not to spend to much cash saving up for a brand new GT-500
Old Aug 29, 2007 | 03:48 PM
ben790450's Avatar
ben790450
I ♥ Acer
ORIGINAL: BADSEED
ORIGINAL: ZW99GT
What? Ive never heard that. 70 hp!?!? Are you sure you dont mean putting 99-04 heads on 96-98?? The heads are exactly the same from 99-04. . . . But you should port and polish them either way. Stage 2 cams are meant to work with aftermarket or ported heads. Its pointless to get stage 2 cams with stock heads.
