Time to take it a step higher - 12 PSI
ORIGINAL: 2002GTAUTOVERT
wtf are you talking about? haha
your numbers at 8PSI = my numbers at 10PSI
YOU BASTID!!!
what size injectors do you plan on running?
ORIGINAL: mylongvictor
My 12psi pulley is coming soon..... Hopefully my numbers will be just as impressive!
YOU BASTID!!!
Ony 42lbs right now..... I don't think I'm going to need 60lbs until I pass the mid 500rwhp mark..... which I don't forsee even with the 12 psi pulley swap..... Because I'm still on my stock PI heads.[:@]
Now when my Stage II heads come in...... Then yea.... Those 60lbs are going in!
YOU BASTID!!!
YOU BASTID!!!
stock PI heads? ouch man get those suckers ported !!
i hear ya.. my tuner said if i throw the 12psi pulley on i could go lean at WOT. im lookin for 60's. id probably be close to your numbers, but my car is choking to death (no long tubes). damn visual emmissions inspections in NV =( and i drive the car too much to get a waiver. SON OF A B****
YOU BASTID!!!
YOU BASTID!!!
Yea.... I have people that will pass me for emmissions for my Long Tubes.... but....... I'll scrape just about everything on the damn road that sticks out more then 2 inches off the ground...[:@]
Didn't Nanaki gain like 10hp at the wheels from shorties to LT's? I'm starting to think that shorties aren't as inferior as everyone makes them out to be, once you start making some good power.
ORIGINAL: ZW99GT
ORIGINAL: ZW99GT
ORIGINAL: Rusmisel01GT
That is true... but it also dropped her boost about 2 pounds... So it proves how much better it helps the car breathe.
ORIGINAL: ZW99GT
YOU BASTID!!!
YOU BASTID!!!
ORIGINAL: contentsunderpressur
Ok, something weird is goin on here. I have the svt focus pump and kb boost a pump. I'm runnin a 3.2 pulley on my p-1 procharger which should be around 12 lbs of boost. I have vt stage 2 blower cams, stage 2 heads and longtubes. My 42 lb injectors held up no problem but the pump, even with the boost a pump, hit 98 % at WOT. My car only made 434 rwhp with this setup with the a/f perfect. I think my tuners dyno must show lower numbers for some reason. The reason I think this is because I made 506 rwhp with the nitrous and blower. Last weekend a guy had a gt with the exact same stuff done to it but he had it put on a different dyno. He said he made 518 rwhp with just the blower. We raced at the track last weekend. We came off the line with the same 60ft but I run off from him pretty good by the time the race was over. I beat him by over three tenths of a second. He went a 7.91 to my 7.59. What's funny is that I run a 7.74 on motor with just 434 rwhp to his 7.91 with 518 rwhp with the same 60 ft? WTF.
YOU BASTID!!!
YOU BASTID!!!
