Snow Perf. kit
Old Sep 24, 2007 | 09:00 AM
35thAnni99GT's Avatar
35thAnni99GT
From: Where gunshots are more common than birds chirping
Default Snow Perf. kit
I remember seeing a thread/stickyon info about Meth/water injection. My cookies are all ****ed on my browser so I can't search, sometimes barely post so could someone dig it up real fast? My main questions were
1) Will I benefit from this kit even with an I/C? If so, how much of a gain shouldwith H/C/I/LTs on 10 psi? Is it comparable to running a small shot of nitrous as far as cost effectiveness?
2) How difficult is installation? Should I have a shop do it?
3) Does it spray all the time or only when I flip a switch to make it do so? If so do I need to get a separate tune to run on the meth?
Old Sep 24, 2007 | 12:03 PM
lizzyfan's Avatar
lizzyfan
Underboss
Default RE: Snow Perf. kit
ORIGINAL: 35thAnni99GT
1) Yes as you'll be able to run more timing
2) Not to hard if you have a little mech ability, but after install you need to hit a dyno to have a re-tune
3) It has a controller that you can adjust to spray times, ie. 3 psi
Here is my writeup, which is straight from the Snow site: https://mustangforums.com/m_3430620/tm.htm
Old Sep 24, 2007 | 01:41 PM
ktm300's Avatar
ktm300
Snow Performance
I have some pics of the system installed in my car, the install is easy to do. I have a switch for mine, and a separate tune via KB switch chip. But its always on anyways.
Old Sep 24, 2007 | 02:08 PM
contentsunderpressur's Avatar
I found out first hand that it's not worth putting it on a intercooled car. Non intercooled cars pick up big numbers but not intercooled ones. My tuner added 5 degrees of timing to my buddies car and it only gained 10 rwhp. That was a procharger D-1 running 19 lbs of boost. The very next day another buddie of mine had his car tuned with a non intercooled vortech on the same dyno and picked up 50 rwhp with the meth.
Old Sep 24, 2007 | 03:04 PM
nanaki's Avatar
nanaki
Retired MF Moderator
and i found out first hand it CAN add quite a bit of power. 500RWHP to 530-540RWHP is a nice jump. chris @ excessive put a meth kit on an already IC'd 500RWHP fox and they get it up to around 540RWHP on boost juice.
Old Sep 24, 2007 | 04:18 PM
35thAnni99GT
Great information and thanks for the help guys. I was attracted to it because it looks like a really cost effective way of boosting power without much risk of detonating the motor and after the reading the feedback I don't know why more people don't do it. I still have to install my blower and new tranny so I'll probably save up for this mod to do myself this winter.
Old Sep 24, 2007 | 04:19 PM
JJ03MustangGT's Avatar
JJ03MustangGT
1.) how often do you guys refill the meth a week?
2.) did your gas mileage suffer or get better?
3.) where do you get your meth from?
4.) what kind do you use?
Old Sep 24, 2007 | 05:56 PM
mustangmancp's Avatar
mustangmancp
do you have to be s/c to use it??? or is it not really effictive if ur n/a???? jw
Old Sep 24, 2007 | 08:59 PM
mustangmancp
anyone know???????
Old Sep 24, 2007 | 10:02 PM
35thAnni99GT
Looks like any car that would benefit from a colder, denser charge of air would benefit from this one. I wonder why more people don't run it?
