wet differential
Old Sep 25, 2007 | 12:33 PM
robs400's Avatar
robs400
Default wet differential
I was installing some adjustable shocks in my car the other day and noticed that the differential was wet on the bottom side of it. I have never had the rear end cover off and my car only has 25k on it. I do jack it up from the from differential which I have heard isnt the best place to do it, but it was not bending the cover at all back while I did it. It has never left a spot on the ground but there is enough fluid to make me curious as to why its like that?
Old Sep 25, 2007 | 02:22 PM
contentsunderpressur's Avatar
Default RE: wet differential
Find out if it's coming from the plate on the back or the pinion from the front.
Old Sep 25, 2007 | 02:41 PM
lizzyfan's Avatar
lizzyfan
Underboss
Bad pinion seal?
Old Sep 25, 2007 | 02:55 PM
GhostRider02GT's Avatar
GhostRider02GT
I know mine has a bad pinion seal. It leaks from there, but never looses fluid, just shiny and most all the time. Im took lazy to replace it, itll get redone when I rebuild the rear end.
Old Sep 25, 2007 | 03:10 PM
robs400's Avatar
robs400
Its not coming from the pinion area, its coming from the cover I can see where the seal is squished out a little bit and its wet. I suppose I could try tightening up the bolts some more, but like I said it has never been apart....
Old Sep 25, 2007 | 03:20 PM
GhostRider02GT
worst case, buy new seal and gear lube
Old Sep 25, 2007 | 03:24 PM
Adam03GT's Avatar
Adam03GT
This happend to me a little while back. I bought the car and the differential was like that at 36k miles. Over a year or so later it began leaking so bad that i was leaving puddles everywhere.
It was either because it had hit something or been jacked up by it... I would just fix it now before it actually becomes a problem.
mtgldr
Feb 3, 2024 09:00 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
UrS4
Oct 3, 2015 06:23 AM
KingRando
Oct 2, 2015 08:06 AM
Sep 8, 2015 11:50 AM
