mach stereo
Old Sep 27, 2007 | 04:47 AM
johnmvtv's Avatar
johnmvtv
Default mach stereo
I got an 02 with the mach stereo.The front speakers next to the windows sound like a$$.I can turn down the base,but it sounds good in the back.Has anyone replaced these?Any suggestions on what speakers i could put there?Thanks
Old Sep 27, 2007 | 05:05 AM
SlvrOhTwoGeeTee's Avatar
SlvrOhTwoGeeTee
Default RE: mach stereo
From what I hear due to the factory speakers having a different Ohm load then normal aftermarket speakers you can't just swap them. If you want to start swapping out componants you will need to swap them all out.
Old Sep 27, 2007 | 08:04 AM
02WhiteGTVert's Avatar
02WhiteGTVert
the stock speakers on the Mach system is 2ohm. if you replace them with aftermarket speaker's they'll cut out once you turn the volume up. it's an easy replacement,find a mustang with a mach system,convertible,hardtop,v6,gt,doesnt' matter. take the door panel off,and if i remember correctly it's 4 phillips screws holding it in. hope that helps.
Old Sep 27, 2007 | 08:20 AM
Sxynerd's Avatar
Sxynerd
Just rip out hte MACH... It's crap. I work at BestBuy as a Installer and they pretty much suck as far as sound systems go. I tell everyone with it they should rip it all out and start over. Get a nice 4 chanel Rockfort (or better) and maybe a mono/2channel for a small sub and be done with it.
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
