AC PROBLEM
Old Sep 27, 2007 | 05:40 PM
fast929rr's Avatar
fast929rr
Default AC PROBLEM
I have a 96 gt and the ac is coming out of the defroster it just started yesterday what can i check
Old Sep 28, 2007 | 06:20 PM
contentsunderpressur's Avatar
Default RE: AC PROBLEM
There is a small black vacume line coming out of the firewall under the hood where your ac freon lines go into the cab. Sounds like that line come loose from the motor. When you loose your vacume it goes straight to defrost. If that's not it it could be your selector switch or your blend door actuator.
Old Sep 28, 2007 | 06:54 PM
fr8flyer's Avatar
fr8flyer
The vacuum line is not a rubber hose where it goes thru the firewall, it is made of plastic. Ford does not sell them, neither does Napa, Discount or Auto Zone. The Ford dealer told me to just replace it with a rubber vacuum hose. You will have to remove your glove compartment to find where it connects to the valve (black cylinder shaped), it's way up there. When this vacuum line breaks or vacuum is lost from the valve the system is designed to make all the air go out of the defrosters so your windows won't fog up.
Old Sep 28, 2007 | 06:57 PM
fr8flyer's Avatar
fr8flyer
My vacuum line was broken in two so I put a rubber vacuum line connecting the two pieces. The a/c works fine again.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
