Winter Storage
Old Oct 11, 2007 | 03:40 PM
Pietrasz4's Avatar
Pietrasz4
Default Winter Storage
I just recently put my car away for the winter, and took it off the insurence but just kept it on theft and fire. Right now it has a half a tank of gas, what exactally do I need to put in there to keep it fresh? Also is there anything else anyone would suggest I do to the car?
Old Oct 11, 2007 | 05:09 PM
xander0561's Avatar
xander0561
Default RE: Winter Storage
There is a company called "Stabil' or somthing like that, it lets you store your cars, boats, RVs over long periods of time. The thing is that I think you need to run it through the fuel system alittle to take full effect.Example: when you add it to your gas, you run the car for a few miles.
Old Oct 11, 2007 | 05:54 PM
MrChubs1's Avatar
MrChubs1
Drive it!!
Sorry, down here that's what we do all winter. [sm=icon_stickpoke.gif] [sm=laughat.gif]
Old Oct 11, 2007 | 05:58 PM
Pietrasz4's Avatar
Pietrasz4
IfI wasent able to put gas tank stabilizer in there would it be bad to leave the gas in there for about 6-7 months?
Old Oct 11, 2007 | 06:07 PM
mustangman02232's Avatar
mustangman02232
bridgestone blizzaks FTW
seriously tho
fill the car up with fuel
change oil/filter
detail it fully
buy some foam pads to park on (NOT jackstands)
battery tender (not charger)
Old Oct 11, 2007 | 06:48 PM
Triisomy21's Avatar
Triisomy21
Seriously, go get it and fill it with gas. Then put some stabil in it. When was the last time you changed your oil?
I put my stock wheels back on when I put mine away last year and the tires were fine after sitting in one spot for 6 months. But if you only have one set, check tirerack.com for some pads.
Old Oct 11, 2007 | 06:54 PM
01snake's Avatar
01snake
i did the same on wed.
on svt they said:
-a full tank of gas. with some stabilizer
-disconnect batt.
-more then 6 months shot soem stuff in each injector place
-put carpet or sumthing under the car to keep moisture out
-maby roll onto styrofoam or lift on jacks to keep flat spots off tires
-change oil before storage and change it again when taking it out
there is a a specific site i will try and get it
Old Oct 11, 2007 | 08:35 PM
blownbayou's Avatar
blownbayou
Thank God I live where it gets a blustery 45* in the winter
What 01 snake said is about right if I had to do it
Old Oct 11, 2007 | 08:36 PM
blownbayou's Avatar
blownbayou
btw.....That hit shows how tough Ocho Cinqo is......DAYUM!!!!!
Old Oct 11, 2007 | 08:40 PM
greenyGt's Avatar
greenyGt
ah i could never store my stang over the winter
to much fun in the first 1/2 inch snow=]
