Got 6 Speed????
Old Oct 15, 2007 | 04:45 PM
02 Ninja's Avatar
02 Ninja
Default Got 6 Speed????
Has anyone swapped their tranny for a 6 speed? If so, what is the biggest difference, what all needs to be done and most important, how much did everything cost. I've been tossing around the idea of making that my next major move. What do you guys think?
Old Oct 15, 2007 | 04:57 PM
2002GTAUTOVERT's Avatar
2002GTAUTOVERT
Default RE: Got 6 Speed????
i think its a good idea.. i think the 6 speed you can drive conservatively and keep the rpms even lower than the 5 speed.. but i dont know how often youd use 6th gear? maybe for 100+ but at that point you dont want to shift and leave the powerband.
i think the 6 speed would really be complimented by some 4.30's and from what i understand, they are 10x better that what you guys got from ford (clunky *** 5 speeds)
Old Oct 15, 2007 | 05:11 PM
02 Ninja's Avatar
02 Ninja
Do you know how much they cost?
Old Oct 15, 2007 | 05:14 PM
Xemeth's Avatar
Xemeth
The t-56 is over $2500, I think. Really if you want a stronger tranny I'd just go with a TKO.
Old Oct 15, 2007 | 05:15 PM
defconfire's Avatar
defconfire
Actually the 6th gear is very close to our fifth gear. I think the 6th is a .64 and our fifth is a .67 or .68. the ratios are just closer together so you spend more time in your powerband.
Old Oct 15, 2007 | 05:18 PM
2002GTAUTOVERT
a rebuilt T-56 can be had for around 1300... but it is a used transmission.
6th is .63 but close enough... i think its a step above your 3650 but a step below a new TKO.
Old Oct 15, 2007 | 05:19 PM
y2kStangGT's Avatar
y2kStangGT
ORIGINAL: defconfire
what are those ratios stand for anyway?
Old Oct 15, 2007 | 05:27 PM
Xemeth's Avatar
Xemeth
ORIGINAL: y2kStangGT
The size of the ratio between the driver gear and the driven gear. The ratio determines torque multiplication. That's why you have almost no pickup in 5th gear, and a whole **** load in first.
Old Oct 15, 2007 | 05:30 PM
defconfire's Avatar
defconfire
The number of input rotations compaired to output rotations. So technically it is 0.67 engine rotation :1 drive shaft roatation . Similar to the way rear gears are rated.
Stock rear end gears = 3.27 rotations of the drive shaft would be equal to 1 rotation of the wheels. So its 3.27:1
Old Oct 15, 2007 | 06:30 PM
01snake's Avatar
01snake
you can get a fully built d&d t-56 for around $3,000
