Adjustable Shocks/Struts for a DD...worth it?
Old Oct 29, 2007 | 11:07 AM
99GTvert's Avatar
99GTvert
is my username.
Default Adjustable Shocks/Struts for a DD...worth it?
I plan to take my car to the track at least.... 5 times a year, and I also DD my car.
My rear shocks are squeakin' and need to be replaced sooner or later. My ? is, should I get adjustables all the way around or just get regular shocks/struts?
Old Oct 29, 2007 | 12:07 PM
DragonOfBC's Avatar
DragonOfBC
Default RE: Adjustable Shocks/Struts for a DD...worth it?
I've got the adjustables and I love them. I'm usually a fan of tight suspension when I'm driving around on my own so I keep them set them 5/6. I was driving some people on a trip and they were complaining in the backseat about how bumpy the ride was so I just hopped out and dropped the shocks down to 3. It was a completely different ride.
I don't change them often but there are sometimes it's nice to depending on your driving circumstances. I've tracked my car a couple of times and its my dd.
Old Oct 29, 2007 | 01:33 PM
BleedinBlue's Avatar
BleedinBlue
If you can afford them, absolutely get them.
Old Oct 29, 2007 | 01:47 PM
DragonOfBC's Avatar
DragonOfBC
They aren't too expensive. Full set of Strange S/S can be had for $400
Old Oct 29, 2007 | 01:50 PM
99GTvert's Avatar
99GTvert
is my username.
Thanks guys. I'll probably get adjustables then.
What exactly is involved in adjusting them? Do I need to jack the car at all?
Old Oct 29, 2007 | 02:11 PM
DragonOfBC's Avatar
DragonOfBC
No jacking required. I can lay on the ground and reach around each of the wheels to make adjustments. You have to turn the steering wheel to get at the front ones.
I snapped the picture below from just behind my rear tire. To give you perspective, the clamp on the right is the exhaustand you can see my driver side rear tire on the left side of the pic. The little dial on the bottom twist and "click" for each setting. I've done it with the car running before (just watch because the exhaust pipes are hottt).
Old Oct 29, 2007 | 02:13 PM
DragonOfBC's Avatar
DragonOfBC
Another pic. A little further out
Old Oct 29, 2007 | 02:19 PM
99GTvert's Avatar
99GTvert
is my username.
oh ****, sweet.
Damn I want to get some ASAP! Thanks.
Old Oct 29, 2007 | 05:02 PM
GhostRider02GT's Avatar
GhostRider02GT
stange or they have tokico adj drag shocks, settings for the strip and 1 setting for the ride home, but they are like 185 a piece
Old Oct 29, 2007 | 06:03 PM
99GTvert's Avatar
99GTvert
is my username.
KYG a good brand? They have then on AM.
http://www.americanmuscle.com/shock-strut.html
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
