NOS manifold
Old Nov 1, 2007 | 09:51 PM
josh.davis's Avatar
josh.davis
Default NOS manifold
I need to know how many of you run NOS with stock manifold.....?
b/c i am having trouble getting my self to buy the hardball'r intake for $700. I would rather buy some cams or somthing that could give me more power.
Old Nov 1, 2007 | 09:58 PM
sickness's Avatar
sickness
Default RE: NOS manifold
i just have a spare stock one and spray the hell out of it...
my old car coughed on a 225 shot with out a plastic intake and it was still ugly???
Old Nov 1, 2007 | 10:00 PM
02 Ninja's Avatar
02 Ninja
cams are gonna cost you more than spray after install.
Old Nov 1, 2007 | 10:05 PM
01GT4.6's Avatar
01GT4.6
I've sprayed NX for 4 years on mine w/ no problems, get all the safety stuff and you should be fine.
Old Nov 1, 2007 | 10:07 PM
oxfordgt's Avatar
oxfordgt
Future refrence NOS stands for nitrous oxide systems. Nitrous is what you run not NOS. Stop watching fast and the furious.
02ninja is right cams will cost more plus its better to be safe than sorry so get a good intake. If you blow that plastic one it could shoot plastic into the heads and bend valves which will cost alot more than $700.
Old Nov 1, 2007 | 10:08 PM
02 Ninja's Avatar
02 Ninja
ORIGINAL: 01GT4.6
+1
Old Nov 1, 2007 | 10:15 PM
JayC's Avatar
JayC
ORIGINAL: oxfordgt
Where did you get this BS? I've never heard of plastic getting into the heads and bending valves. I've personally blown 2 plastic manifolds and never had such a problem. A used manifold bought for less than $100 and a couple of hours and I was back on the road. Maybe you'd feel safer with a direct port and a aluminium manifold.......check this pic.....
Old Nov 1, 2007 | 10:23 PM
01GT4.6's Avatar
01GT4.6
ORIGINAL: JayC
ORIGINAL: oxfordgt
I was thinking the same thing, doesn't the manifold explode, not implode?
Old Nov 1, 2007 | 10:26 PM
josh.davis's Avatar
josh.davis
well ****........... so should i buy another stock one our the hardball'r..... When it happen, i wasn't running a window switch, but i do have one now.. It is a wet system.
Old Nov 1, 2007 | 10:28 PM
oxfordgt's Avatar
oxfordgt
I read about it about a year ago. Plastic shards fall back in and get sucked into the head. It happens more often on the chevys but I have heard of it happing on mustangs. If your nitrous backfiring that much you have a really bad system. Upgrade your nossles and get your pressure right. You got way to much fuel pooling.
