more problems
Old Nov 2, 2007 | 03:56 PM
4literGasEater's Avatar
4literGasEater
Default more problems
ok so when i got my car tuned about 2 weeks ago we ran into some serious problems. I made 290hp with my pump at 100 percent duty cycle. I had the shop put in 750cc injectors and a focus svt fuel pump. Today the car made 318hp. Now i am really pissed, it may be bad valve springs or ignition but i am running out of freaking ideas. Anything like this ever happen to anyone out there? suggestions please!?!?!
Old Nov 2, 2007 | 04:33 PM
josh.davis's Avatar
josh.davis
Default RE: more problems
more info?
Old Nov 2, 2007 | 04:43 PM
4literGasEater
The car has a p series pro charger, and i did do a complression test. The lowest compression was 155, the highest being 175. It now has a MAFIA mass air flow so it wont lean out on top end my air fuels are perfect all across and i am running 11 pounds of boost.
Old Nov 2, 2007 | 05:15 PM
oxfordgt's Avatar
oxfordgt
What kind of car? 318 is very low even for a non pi (if thats what you have). 155 is very low compression for these motors. We need more info on your car and what you have done to it.
Old Nov 2, 2007 | 06:36 PM
2002GTAUTOVERT's Avatar
2002GTAUTOVERT
ORIGINAL: 4literGasEater
how much LB/HR is that? i dont remember our fuel pumps topping out until over 300rwhp (this is assuming these are RWHP numbers) if your tuner only got 318 rwhp from a supercharged 4.6 id say get your car off the dyno and take it somewhere else. you need to go with a colder plug but that wont steal 50hp from you. what PSI are you at?
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
