Clutch help
I don't know much about clutches... but car grinds going into third gear.. and its very hard to get it into first gear w/o fully stopping.. also. when i take off in first it feel like it starts off in third..it hesitates.. So i was wondering if I need a new clutch.. if so.. what kind of clutches do u guys recomend
02 black/black gt, 5sp, kenne bell 2.1 intercooled
Syncros are little cones in the transmission that match the teeth on the sleeves with the teeth on the gears in the transmission so it makes it easier to shift into gears. They basically syncronize the movement of the teeth, hence the name.
But I agree with ZW. With the transmission out might as well upgrade the clutch. I don't recomend putting in new syncros yourself, though. You need an experienced mechanic to do it. I've done it before, and it's a pain in the *** the first time or so.
ORIGINAL: znasrah
I would pick-up on your clutch pedal and get all the slack out and see if anything improves. If anything improved at all even the slightest bit, your almost guaranteed it's your clutch. Syncros don't get any better no matter what you do.
Also, have you tried running the car through the gears without the clutch? I did this on my Z-28 and it shifted perfectly. That's how I knew something was wrong with my clutch install. This does take practice and you can damage your trans. if you do not know what you are doing. I suggest not doing this if you have never done this before, especially now with your issue.
forks arent on the clutch covers. forks are comonly refered to as the shift forks which can sometimes get bent. it is very uncommon for the fingers on the diaghram to bend. it sounds like a syncro problem to me as it is only in selective gears. a clutch problem usually persists in every shift. try double clutching into the gears you commonly grind. if you dont grind when double clutching that usually means your syncros have gone bad.
