wow
Old Nov 10, 2007 | 12:22 PM
  #21
Fobra's Avatar
Fobra
Banned
Default RE: wow
ahh i see now... youre right... i still dont see you being able to turning the timing down enough to run pump on something like that, but i guess its possible.. little things in the vid still dont make sense tho
Old Nov 10, 2007 | 12:25 PM
  #22
livefast1's Avatar
livefast1
Default RE: wow
eh yea it is a wierd situation, but i take back the show car thing, if you look at him before he gets into the car he turns the cutoff switch on in the back of the car (kind of a drag car thing with the battery in the trunk) , the cage, i will agree with it looking like its the kids dads car. he looks real nervous in the video, if it was his car he wouldnt of hit that bucket, and in the other clips i think there is an older guy messin with it.
Old Nov 10, 2007 | 12:29 PM
  #23
ben790450's Avatar
ben790450
I ♥ Acer
Default RE: wow
ORIGINAL: banned
alot of things in that vid dont make sense to me 1) look around the room 2) look at the bucket in front of the air dam, he does a burn out in front of that? 2) factory cobra R's? 3) not even tubbed? 4) look at the ground behind the tire, if he did a burnout like that with that amount of power, it would fling rubber 10 ft away, the floor is still clean... but it does have a cage... i dont know its wild... the only point i was trying to make was that the odds of that motor a) runing on pump gas and b) only making 800 hp... are slim and none
My friends father has a 550 rwhp 2000 lbs SCCA 69 mustang. He can sit in one place and do burn outs like that on 13" wide slicks and not move two inches. He doesn't sling tread anywhere. He did it with a 79 mach sitting in front of him too.
Old Nov 10, 2007 | 06:42 PM
  #24
97targa's Avatar
97targa
Default RE: wow
Bullsh.t! Lok at when he starts the brake stand. The driverside tire breaks loose a good second before the pass side. With that kind of power they would both break loose instantly.
Old Nov 10, 2007 | 09:44 PM
  #25
kenv's Avatar
kenv
Default RE: wow
I`d drive it, LS1`s here I come
The reason he looks nervous is because he probably peed himself a little when he hit the gas
Old Nov 10, 2007 | 10:08 PM
  #26
01GT4.6's Avatar
01GT4.6
Default RE: wow
ORIGINAL: 97targa
damn you are amazing!!!! You must have the best vision to actually see when the passenger side rear tire started spinning from the front drivers side angle. All I could see is the smoke was rising at the same rate on both sides, smoke actually coming up through the engine compartment and you can see the black mark from where he rolled a few inches up.... besides he has other videos of the same car.
Old Nov 10, 2007 | 10:22 PM
  #27
contentsunderpressur's Avatar
Default RE: wow
It is very easy to run a 871 blown motor on pump gas. It's not the size of the blower, it's the amount of boost. There were several cars at cruzin the coast this year that had those blowers running up and down the strip, on pump gas. Hell, I've seen a car with a F-1 blower that was only making 10 lbs of boost with a super big pulley running pump gas.
Old Nov 10, 2007 | 10:23 PM
  #28
Injected97GT's Avatar
Injected97GT
Default RE: wow
i think its hilarious that the guy arguing that it HAS to be fake and CANT run on pump gas, and he KNOWS what he is talking about, couldnt even read that its an 8-71 blower, and thought it was 871 cubic inches BAHHhahahahahah
Old Nov 10, 2007 | 10:39 PM
  #29
Default RE: wow
It clearly says it's a 871 blower on a 43x cu in windsor.
Old Nov 10, 2007 | 10:55 PM
  #30
Injected97GT
Default RE: wow
ORIGINAL: contentsunderpressur
SHHHH! dont let the captain know it all, engine god know that, its IMPOSSIBLE. the entire video is a fake!
